ecu swap
Discussion in 'ECU's, Electronics, and Tuning' started by rex187, Aug 24, 2005.
  1. rex187
    rex187 Member
    austin,texas
    i was wondering if any one could tell me if swaping the sir pr3 that is in my rex with the sir2 p30 ecu? i think it can be done with a obd0 to obd1 conversion harness and i think maybe obd1 dissy to but im not sure. also when swaping the ecu's is it possable to add the hondata s200 system with boost upgrade?
  2. evoracer03
    evoracer03 Senior Member
    needed:
    obd1 ecu
    conversion harness
    dizzy/ conversion for obd1 dizzy
    injectors/ bypass the resistor box
  3. pissedoffsol
    the injectors are fine-- the car has a resistor box on it and needs it to run peak/hold injectors.
    you will also need the VSS. it sends out different pulse widths.
