Originally posted by darien234@Apr 6 2005, 01:45 PM
You can find a DOHC OBDO dizzy kind of easy is the hatch DX or SI if it is not an SI you will have to find a resistor box, and ecu. You will have to pin 2 wires into connecter A for 2 more injectors like pin a3 and a4 I think. Just look it up here on the swap it has all the ifo you need its pretty easy.
[post=483716]Quoted post[/post]
Originally posted by redef91+Apr 6 2005, 02:51 PM-->darien234@Apr 6 2005, 01:45 PM
thanx for the info so just get a 0b0 dizzy and ecu right its a dx
[post=483753]Quoted post[/post]
Originally posted by redef91+Apr 6 2005, 12:51 PM-->darien234@Apr 6 2005, 01:45 PM
Originally posted by MikeBergy+Apr 7 2005, 03:17 PM-->Originally posted by redef91@Apr 6 2005, 12:51 PM
I might be wrong, but with a DX, don't you also have to do a DPFI to MPFI conversion? That is a system also needing to be modified, it's not simply a distributor change.
(shameless jacking) I have an OBD0 integra distributor for sale if you need it. (/end shameless jacking)
[post=484304]Quoted post[/post]
