Ecu Throwing A Code
Discussion in 'ECU's, Electronics, and Tuning' started by brc80, Apr 3, 2003.
  1. brc80
    brc80 Senior Member
    Southern California
    I have a 1st gen b16 in my 90 teg(I know i should have stayed with the b18.) But my problem is my ecu is throwing a code 2. So i did a search and it says its a secondary 02 Sensor, but im obd 0 so i dont have one. Is there another chart with codes for obd 0 cars? If not does anyone know what that code means. Thanks in advance for the help.
  2. brc80
    brc80 Senior Member
    Southern California
    Anyone?
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    hmm, your supposed to have a second o2 sensor, if your running a jdm pr3 obd0 ecu
  4. brc80
    brc80 Senior Member
    Southern California
    AND WHERE IS THAT LOCATED, THANKS.
  5. brc80
    brc80 Senior Member
    Southern California
  6. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    On a 1st gen 88-91 B16A, there are 2 O2 sensors. One leading and one trailing.
    Both are located in the exhaust. You will need to add the 02 sensor and appropiate wire to the ECU to get the codes to clear.
    Check www.hasport.com for more info.
    Or
    www.hondata.com
    Both sites have the info you need.
  7. brc80
    brc80 Senior Member
    Southern California
