Ecu to Laptop
Discussion in 'ECU's, Electronics, and Tuning' started by kakaroto_ss4, Apr 11, 2007.
  1. kakaroto_ss4
    kakaroto_ss4 New Member
    hey i have a p08 and i want to connect it to my pc. can someone tell how i can do it how i can make the USB cable thing by my hands a tutorial for honda ecu like p28,p08,pm7 u know please help.:mellow::mellow::mellow:
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    To tune or just for looks? If you're just datalogging, you can make a Datalog cable(search Nokia Datalog cable on google or something; uses Prolific IC) and install something like Freelog on the computer. Also, you'll need a header to connect it or just solder the wires directly.
  3. kakaroto_ss4
    Yes mam but i need a manual to make the datalogin cable.
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Just postin so you could read my sig................LMAO
  5. K2e2vin
    Raleigh, NC
    pgmfi.org :: View topic - How To: Nokia Datalogging Cable
    Attached is a picture of mine; I skipped the whole taking apart the converter and just made a cable using a cd-rom drive audio cable and putting a female db9 hood/connector on the other end; and just hook it up to a simple DB9/Serial->USB converter.
  6. cua0
    cua0 New Member
    which pins on the DB9 did you connect your CN2 pins to to make it work?
  7. K2e2vin
    Raleigh, NC
  8. nootrac22
    exeter pa
    that's just for data logging, correct?
  9. K2e2vin
    Raleigh, NC
  10. ls ef
    ls ef New Member
    you can get the cable from walmart. If you dont wanna mess with your ecu you can send it out. McCarron ECU Services
    I bought my ecu from him it was chipped and socketed with a basemap for my specs.
