ecu turbo tuning
Discussion in 'ECU's, Electronics, and Tuning' started by crxpower24, Apr 9, 2012.
  1. crxpower24
    crxpower24 Member
    hello im geting ready to boost my d15b7 n ppl keep telling me dat i need to tune my ecu wat do they mean by dat or how to do it do i jst put a aftermarket chip from ebay or take to a shop can some body help me
  2. 99sidude
    Ohio
    You need something like Hondata or Crome, and someone with a dyno and tuning experience. A generic chip will cause you to blow your engine.
  3. crxpower24
    crxpower24 Member
    can dey jst tune da ecu or i have to buy a hondata
  4. adecorzo
    adecorzo TronicsClub.com
    yes i would like that too can they just use chrome on the stock ecu or what?
  5. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Yes and no, You can tune a factory ecu with chrome, uberdata, neptune etc. Before you can tune it you need to have the ecu modified with a socket and a re-writable eeprom chip. Than you can flash new maps on the new chip to your hearts content assuming you have a chip burner or take it to someone who does.
  6. |Chaz|
    |Chaz| Well-Known Member VIP
    I'd just buy a chip off of ebay, it'll be good for at least 400hp. You won't even have to build your motor.
  7. crxpower24
    crxpower24 Member
    so can i just buy 1 of does $20 chips on ebay cuz im only gona run 5psi
  8. |Chaz|
    Yup, that'll be exactly what you need.
  9. Fernpatch
    Fernpatch Member
    Bellingham,WA
    This is something that I would not do. Any chip you buy on most websites will be a base map at best. They are never a final solution IMO. I would recommend checking around your local area and see if there are any tuners that can actually burn a chip for YOUR car instead of buying a cheap GENERIC unit from ebay.
  10. |Chaz|
    Apparently you missed the sarcasm.
  11. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Yes and no, I knew you were being sarcastic but I didn't know if crxpower24 would know that you were trying to be funny. I am also trying to look out for future noobs who may stumble across this thread and take your last post very seriously. My apologies if I stepped on your toes in any way.
  12. |Chaz|
    No worries, I was just being an asshole anyways.
  13. SpoonMotorSports
    SpoonMotorSports New Member
    peshawar Pakistan
    You need crome
    27c256 eprom chip
    and a custom tune
    btw one of my frnds did a 5psi b16a with only a fpr and larger 440cc injectors on stock ecu - it would only run on 92octane otherwise it would knock real bad on 87octane
    so 5psi and a so so basemap will work just fine
    but if you really want reliability then head for a local tuner and let him do things his way
  14. thenoxus1
    thenoxus1 Quick-Spool Racing LLC
    MD and PA
    Basemaps are good to get to a tuner and that's all..
    They don't account for your AFR at all. If you modify any engine besides a basic I/H?E you'll want a tune. PM me if you need Hondata units.
