Need Ecu Wiring Help
When Performing A Dpfi/mpfi Swap How Do You Depin The Ecu Plugs? I Pulled The White Clips And Inserted A Pin But The Wire Would Not Pull Out. Also The Wire Swaps I Have Printed On The Ecm Terminals Do Not Match The #'s On The Plug. So When Someone Says Swap C1 And C2 W/ B10 And B12 Do I Go By The #'s On The Plug? On The Plug B10 Is On The End Of The Of The Plug Not In The Middle..
