  1. AKUMA§KILLERGLASS
    AKUMA§KILLERGLASS New Member
    Cali
    ok so i have a p06 ecu on my 95 civic dx with a jdm d15b in it and i was planning on getting a p28 for $65 from this guy without the harness. so my question is would it be easier to buy an ecu with the harness or should i buy a complete one for $170. is it possible for me to use the same harness i have right now and just switch some wires around?
  2. BrutalB83
    Rochester Hills, MI
    All you'll need is the ECU. There's no point in buying the harness. Your car is already set up for OBD1.
  3. AKUMA§KILLERGLASS
    Cali
    so basically it's a plug and play right? except that i need to get the vtec wires since i don't have them
  4. tvsethi
    tvsethi New Member
    BELLOW DOESNT BELONG TO ME I FOUND IT AND THOUGHT IT MIGHT HELP YOU A BIT : THIS GUY HELPED ME OUT BIG TIME
    Here I've gathered up all legitimate EK wiring information on frequent wiring issues people have when performing an OBD2 B-series engine swap into 96-00 EK civics:
    96-98/OBD2a CIVIC CX/DX/LX/EX WIRING INFO
    1) If reusing a CX/DX/LX engine wire harness you will have to perform these wiring mods to this harness:
    a) add wiring for the VTEC Solenoid (VTS) & VTEC Pressure Switch (VTPS)
    b) perform the IACV mod
    c) add wiring for the Knock Sensor (KS) - IF - using an OBD2 DOHC VTEC ecu or non-reprogrammed OBD1 DOHC VTEC ecu
    d) possibly extend the 2nd 02 wiring (if you're using a US OBD2 B-series ecu)
    e) perform the OBD2a CKF mod - click HERE
    Before, I mentioned to swap the CKF plug over to an integra CKF plug, but this wiring trick is much easier to do.
    2) 96-98 Civic users can use a 5-speed 96-98 EX engine harness to complete their engine swap if they do not want to perform the mods listed in #1, with exception to #D & #E. The 5spd* EX harness has all of the A-C mods integrated from the factory. The only downsides is that you will have to wire in the 2nd 02 sensor manually if using a US OBD2 DOHC VTEC ecu. Using a 5spd EX harness is virtually plug n' play with the exception to extend a few wires and perform the CKF mod (#E).
    *Using a 5spd EX harnesses will greatly cut back on performing most of the wiring mods listed. Make sure you get a 5spd EX harness and not an AUTO EX harness! The EX AUTO harness is designed differently than the 5spd EX harness; you will run into obscure issues with an auto EX harness, that I have yet to figure out.
    NOTE: You CANNOT use an OBD2 integra engine wire harness in any 96-00 civic because of its 2-piece design. EK civics all use a 1-piece design engine wire harness making it impossible to use an integra engine wire harness in an EK chassis.
    3) OBD2a wiring information/diagrams can be found on my technet site here, under the wiring section:
    .:FFS TechNet:.
    4) If you plan to use a 99-00 Civic or 00-01 integra ecu into a 96-98 EK civic, you will NEED a OBD2a->OBD2b jumper harness adaptor. Reaonsbeing is that OBD2a & OBD2b ecu plugs differ and are incompatible with each other. A handful of people sell this type of ecu jumper here, including me.
    99-00/OBD2b CIVIC CX/DX/LX/EX WIRING INFO
    1) Same wiring info as OBD2a in regards to using a CX/DX/LX/EX engine wire harness, but respective to OBD2b ecu pin out locations.
    1b) Honda changed to a smaller distributor(dizzy) plug on all 99-00 EK Civics (CX/DX/LX/EX/ except Si model. This smaller dizzy plug is incompatible with OBD2 B-series distributors. You will have to either change change over to an Si dizzy plug, 96-98 civic dizzy plug, or 96-01 Integra dizzy plug in order to be compatible with a OBD2a/b B-series distributor.
    Some images to help understand...
    96-98 civic / 96-01 integra dizzy 'big' style dizzy plug:
    99-00 civic small style dizzy plug:
    2) OBD2b EK non-VTEC civic owners have an optional choice of using a 99-00 Si or EX engine harnesses (5spd). Again, there is no need for you to add VTEC wiring or perform the IACV fix because like a 96-98 EX harness, its already pre-done from the factory on the OBD2b Si / EX harnesses. The CKF info remains the same for the EX harness. The differences between an OBD2b Si and EX harness is the distributor plug and CKF plug - Si uses a B-series dizzy & CKF plug.
    One issue that might arise is the 2nd 02 sensor if using an Si coupe engine harness. You will have to manually wire in the 2nd 02 because the Si engine harness only has the primary 02 sensor integrated into it. The 2nd 02 is part of the cabin harness on Si coupes & I think 99-00 EX coupe's as well (correct me if I'm wrong).
    3) If you want to use a US 00-01 integra ecu in your 99-00 civic, you need to have the Immobilizer removed from the integra ecu or else your civic will not start. Also, when using a US 00-01 Integra ecu w/removed IMMobilzer, the fuel pump pinout "A16" needs to be moved to over on slot to "A15", in order for your EK to start (fuel pump pin location differs between OBD2b civic & integras). You only need to perform this pin change if using an 00-01 US integra ecu's in a 99-00 civic. If you plan to use an Si coupe ECU, there is NO NEED to perform this pin swap because Si coupe ecu's do not have an IMMobilizer, nor does any 99-00 civic ecu, only 00-01 integra ecu's do. Don't forget that if you ever switch back from using a US 00-01 integra ecu to an Si coupe ecu, switch the A15 pin back to A16!!!
    4) 3) OBD2b wiring information/diagrams can be found on my technet site here, under the wiring section:
    .:FFS TechNet:.
    Code 91 Issues - pertains to both OBD2a & OBD2b vehicles
    There's a MIL code (91) that some of you might get. This is for the fuel tank pressure sensor or "PTANK" as honda labels it. This happens when using a US OBD2 integra ecu in an EK civic, but it's also chassis specific related - as in some civics have this PTANK sensor while other's don't. There are a few fixes for this annoying code and you can read my article about it here:
    .:FFS TechNet : OBD2 Code 91 Issue & Fix :.
  5. AKUMA§KILLERGLASS
    Cali
    well that would be helpful if i had an obd2 civic but i don't i have an obd1 and the ecu is gonna run a d15b not a b-series engine. so it doesn't really answer my question
  6. BrutalB83
    Rochester Hills, MI
    What the hell does this have to do with anything? He's asking about an OBD1 swap into an OBD1 chassis. The info you've posted up is completely and utterly useless to him...congratulations...
    Anyway, to the OP: yes, it should be plug n' play as long as you add the VTEC wiring. If you'd like a nice pre-made VTEC harness, check out Rywire (Rywire - Online Store).
  7. AKUMA§KILLERGLASS
    Cali
  8. BrutalB83
    Rochester Hills, MI
  9. eldiscjockey
    eldiscjockey FrankensteinB18A
    omg plz help. i just go an integra92 b18a non tec, and it was a project, tear down and build buy previous owner, so the c.e.l. wont turn off cant figuer out what is it and i kinda dont trust the code cuz this guy just wanted it to run, bat drains so somethings on, and tachometor wont budge, someone in another fourm told me i should redo the electrical starting with a p28 and a civic fuse box, cant get ahold of him to see if this will work... cuz have 2 p28 i have one on my civic lx d15 and the other was bought just in case the first didnt work, got em a a junki, ne ways. if it ends up being a plug and play or if i have to switch the harness, is this a risk. i dont want to damage the motor or rev up high and then there not be enough fuel distribution, it would be great if the p 28 works cus i can take my lil underdog d15 to 8.4k no problem. befor that i o/R at a lil over 6.5k oviousely with a few mods. but back to the integra, any info would be of great help!!!!
  10. thewraith
    thewraith New Member
    Learn how to write you idiot. Now I have a headache.
  11. BrutalB83
    Rochester Hills, MI
    Was it really necessary to bring back a thread from three months ago to post that?
  12. thewraith
    Talk about the pot and kettle. But yeah- it irked me to no degree.
