ECU?
korey
What ecu will I have to use if I swap a 96 LS into my 97 DX? Also, I will have to use my stock harness for the swap wont I? Are there any problems I could run into doing this swap.
where in the faq does it say anything about this??
i think its an obdII p75. i cant find the link on the new site layout for references. either harness will work. you might have to modify your dx harness because some of the plugs might not be long enough.
