ecu's for b-series motors
B20CIV96
i'm looking to buy a p28 (obd I)manual ecu so i can get it programmed/chipped to run my setup (b20/vtec in 96 civic ex) , but if i can get a p07 for less money would i be lossing out?
Also is there any other ecu's that I can use that can be programmed and chipped? to run my setup (i know i'll have to use an OBDII to OBDI harness)
sigh.
Stay away from P07. They are the "VX" ECU and use a 5-wire O2 sensor, and require some rewiring change.
What motor are you trying to run? A B20 could be run off a chipped P06, P74, P75, P28, P30, P61, P72. A B20Vtec could be run off a chipped P28, P30, P61, P72
