ECU's that work with D16Z6 except P28
b_ricker
I have read all of the posts about the different ecu's that can be used on this forum for 92-95 civics but in the engine swaps 101 on this site it suggests that for the D16Z6 that, "There are several options with the ECU. Either the D16Z ECU or P28 is used, or the stock ECU is retained and a VTEC controller added." Will the PO6 work or is the timing off enough to make it not run. Or is it that only the ECU's with vtec will work with this particular engine. Please list all of the ECU's that will work properly. This is a stupid question but I have searched everywhere. :huh:
the p28 is the choice to use, as its made for the z6.
the p06 can be converted to p28 specs if you can solder and stuff though... but really, IMO, your best bet is to just spend the money on a p28. they aren't that much... 125 bucks ish
