ed6 with b18b1 no start
hondaman152
i just got done swapping an ls into my ed6 and cant figure out y it wont start. i've checked everything and found out it has something to do with the injectors. i used the obd0 ones from my single cam. need help asap
Your distributor, injectors and ecu have to match, meaning if your running obd0, everything must be obd0. If its obd1, everything must be obd1.
What is happening when you try to start it? Is the fuel pump priming?
I still do not understand what your saying... When you crank it, it just cranks and doesnt start? Or the engine starts and then shuts off? Or it cranks and then just stops cranking and you get the "click click click" noise?
