EDM P30 - Socketing and Chipping
Discussion in 'ECU's, Electronics, and Tuning' started by strepto, Jun 23, 2004.
  1. strepto
    strepto Junior Member
    Bergen, Norway
    Hi!
    I have a 1992 Honda Civic VTi with a EDM P30 ECU. I've been trying to find out what is needed to have this socketed and chipped. The problems is that the EDM/JDM ECU's have flat-soldered pins, and not the small holes in the circuit board that the pins go thur. How will this make the socketing process?
    If you know about articles or posts that describe this subject, I'll gladly read up on it more :) Thanks for your help!
    Edit:
    I took the liberty of search a bit, and came up with a few parts that may come in handy:
    M27C256B-80F1 - 32K8 - 80ns - 35 USD for 10
    DIL 28 pin socket from glasspolyester - 50 USD for 50
    If I understand it correctly, I will also need a few other components. Which ones? Again, P30 - OBD1.
  2. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
