Hello everybody !
I'd like to have some advise from people that have already done this Swap ...
I have a 1991 Civic EE9 (the european model ... I am from Switzerland) with a B16A1 engine. I am planning to put a B18C into it...
The question is quite simple ... What should I change to do this swap ? ...
I know that the front engine mount is not the same, and the others are at the same location but I am not prescisely sure.
Also about the conversion of the clutch transmission (keep the cable or go hydraulic).
Other point that is not clear, the harness adaptation ...
If you have any links for adaptation parts for swap I would be happy !
Or simply, if you have answers to my questions, I would be even more happy !!
Thanks for reading ...
