ef 91
Discussion in 'Civic and CRX - EF' started by smok155, Feb 14, 2008.
  1. smok155
    smok155 New Member
    madera ca
    can u change the manifold intake on a dual point?
  2. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    research?!?!?!?!
  3. BrutalB83
    Rochester Hills, MI
    You don't have time for a swap?
    I guess you don't have time to do any reading either, because if you'd have researched this at all, you'd realize there's not much you can do to your shitty DPFI to make it fast.
  4. roninallout79
    roninallout79 Plan B
    GER friggin MANY
    Do the swap
    Swap out your DPFI mani for a MPFI mani. You need a distributor the MPFI mani (obviously), a PM6 ECU if your car isnt running one already. You can use a jumper harness or you can change out the entire engine harness check out ebay or Rywire - Online Store for the harness you need for your application. I just did the swap myself but I changed the engine harness and cabin harness as well. Good Luck brew
    TRU
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what kind do you have is it a si or hf
  6. smok155
    smok155 New Member
    madera ca
  7. AHHVTEC
    Alabama
    opps i meant or hf,,,so do you have a si or hf ?
  8. roninallout79
    GER friggin MANY
    HF soon to be Si minus the sun roof. I have the rear brakes and brackets to do the conversion.
  9. AHHVTEC
    Alabama
    the reason i ask is because if its a hf or si its already mpfi
  10. smok155
    smok155 New Member
    madera ca
  11. BrutalB83
    Rochester Hills, MI
    Pretty sure he was talking to the other guy...
  12. roninallout79
    GER friggin MANY
