Ef B16 Swap Speed Sensor Question
joestud
Do I use the electronic speed sensor for my 91 Civic Si and wire it or can I just use my oem stock 91 Civic Si cable speed sensor instead?
Also the motor won't run because it's not getting any gas. Is there a reason for this? I currently don't have the 2nd O2 hooked up, nor vtec, oil pressure, knock sensor either. Is it a failed fuel pump? It'll turn over but not run.
Joe
