ef -b18 wiring
Discussion in 'HYBRID -> ED-EF / DA' started by taccord1986, Oct 6, 2009.
  1. taccord1986
    taccord1986 New Member
    ok i have a 90 civic hatch that was dpfi i swaped a b18b into it and now i cant figure out the wiring can i use a crx si or civic si harness then use a restior box and a obd0 ecu or what. so basicly the question is what harness should i use what ecu and do i need anything else
    thank you for your help
  2. INJEN78
    INJEN78 HS LEGEND
    you use your existing harness,you will need to swap it to mpfi and obd1..you will also need to get a conversion harness for the ecu.and an obd1 ecu..
  3. taccord1986
    i have the conversion harness for the ecu and the ecu i just dont have the stock harness anymore
  4. Depriesticles
    Depriesticles Kids these days...
    Snohomish, WA
    Ouch. You are going to need your stock harness, or another ef harness in any case. Also, you are going to need the harness for the motor (or certain parts of it) to wire into your ef harness. If you look up obd0 to obd1 conversion and mpfi conversion online, you will find tons of info on how to do this.
    Another option is to tow it to a performance shop that will build you a harness for your motor/car. Its more expensive, but you know it will be done right and clean. Good luck man. I hope you can get it done. I just finished my swap a couple weeks ago so I know how much of a pain it can be.
  5. taccord1986
    thank you for all the info i might just go ahead and try to find a stock harness i am just hoiong it will all work
  6. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Dang MPFI wiring is so easy...
    Get a obd0 engine harness, strip it down, pull the fuel injector, fuel injector resistor box wiring from it, de pin @ tower side plug, get the cabin harness do the same but from shock tower to ecu. Depin and pin as much as you can. This way is alot cleaner and alot less soldering. Depin the injector wires @ cabin harness @ Ecu, swap c1/c2 with b10,b12 , run wires for distibutor sensors from distributor to shock tower plugs, from there to appropriate locations @ ECU to c1/c2. Run the fuel injector subharness from engine to shock tower, from there into their locations at the ecu-A1A3A5A7. It can be done easier, but im anal about wiring.
    The major part of doing it this way is you can easily take it back to DPFI if you ever want to sell it or feel the need. It always looks bad when a potential buyer sees a hackjob engine bay.
  7. taccord1986
    that is what i plan on doing ok so i do have the orginal harness but the dizzy plug is a 5 wire plug and the dizzy plug on my b18 is a 7 wire plug i have to figure out how to wire the dizzy now the 5 wire plug came out of a dpfi 90 civic hatch the 7 wire dizzy plug was a 95 b18 now all i have to do is get that wired and use my obd0 to obd1 harness then do my injectors and the car should run but do any of you know the dizzy wiring
  8. jlicrx
    jlicrx Senior Member
    Colorado Springs
    use this:
  9. taccord1986
    holy crap that is freakin awesome thank you
  10. kongt1
    kongt1 New Member
    what if you have a 91 si with fuel injection and you want b18b in it? What do I need to do with the wiring? Do i really need to set up the format for a dx? How short is the that shifter from the integra should i cut?
  11. D16SiHatch
    D16SiHatch New Member
  12. Briansol
