EF Fuel Pump
Discussion in 'General Tech and Maintenance' started by arpee79, Jan 7, 2004.
  1. arpee79
    arpee79 Senior Member
    It s easy jack the rear up 1st,2nd remove the bolts that hold the plastic guard near the fuel line's.Now you need to unplug the wire from under the rear seat.
    And remember to empty the GAS before taking it down since it will be heavy,the GAS DRAIN plug should be visible under the tank.All thats left if the 2 bolts that hold the entire tank up with straps should take a little while to get those 2 screws of on your back i think it's a 12mm and drop it slow and walla its out.
    I just did this whole thing about 3 weeks ago for a 250lph walbro fuel pump i installed ;) $87.00 on ebay.
