well im stuck in a rutt and need to know what other people have done in this situtation this is my set up and my problem
eibach pro springs
kyb agx shocks
full energy bushings every where
new ball joints tierod ends and wheel bearings
suspensions technics sway bars front and rear
shortend raidus rods 3/16in to give the car more caster
15in drag wheels with 195/55/15s
ingals camber kit front and rear
well my problem is with the cambet kit on my uper controll arm in the front hits the pinch weld so i bent it over. now its hiting on the inside of the strut tower ive ground a little off the controll arm but dont want to go very far as thats what holds the ball joint in how has every one else delt with this problem i dont want to beat the shit out of the strut tower as you will be ablt to see it from the top when you open the hood
eibach pro springs
kyb agx shocks
