EF Hatch Door Moldings
Discussion in 'Body / Exterior / Interior / Cosmetics' started by EF9_boy, Oct 17, 2010.
  1. EF9_boy
    EF9_boy New Member
    TX
    Fixing to paint my car and i'm having hell with the moldings. I know there is a nut at the back that has to be removed, then you remove the door panels and pop the clips to remove the molding. My problem is there are 2 enclosed reinforcment bars running along the inside of the door that the molding clips clip into. How do i pop the clips out or do i have to break them and just buy new ones?:ph34r:
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I'd like to know too because I just broke them, and replaced it with spares from another door molding.
  3. makewheelies304
    makewheelies304 New Member
    ohio
    When we did my car we ended up breaking the clips and buying new ones there a bitch
  4. haao13
    haao13 New Member
    PA
    idk if they are the same as the eg moldings but i just took the panel off and used a long screwdriver. it was still a bitch
  5. Korax
    Korax New Member
    Western PA
    I'm in for this too. I remember looking awhile ago and no one knew from what I read. Everyone just breaks them.. stupid. There is no way I could see to get behind that bar.. unless you cut it which isn't a solution.
  6. EF9_boy
    EF9_boy New Member
    TX
    x2
    and i know it sounds dumb and cheap, but when you are a broke college kid its hard to choose between buying new clips or using that 16 bucks(i was told they are $2 a piece) for lunch or gas
  7. EF9_boy
    EF9_boy New Member
    TX
    Door molding removal
    Started getting ready to paint my car today and figured out how to pop out the moldings and clips without breaking them
    gently pull out and up on the bottom of the molding all the way across except for the very end by the fender(it will pop 4 times, and it feels like you are breaking it) step 2.jpg
    pull out and up on bottom of molding again to pop the top portion of the molding loose step 3.jpg
    once you have the molding loose it will still be attached at the end closest to the fender, push the molding towards the front of the car and it will slide off the clip
    turn the large white clips 1/4 turn and they will come right out step 4.jpg step 5.jpg
    the small red clip that you slide the molding off of is more dificlut to remove, but the way i did it was hold onto it with a set of pliers and wedge it out with a screwdriver
    1 person likes this.
  8. Korax
    Korax New Member
    Western PA
    Yay, rep for you. Until I try it and it doesn't work for me then double negative!! haha.
  9. EF9_boy
    EF9_boy New Member
    TX
    haha alright thanks man
  10. K2e2vin
    Raleigh, NC
    That's what I tried to do with my Accord, but ended up bending the molding
  11. Nykole0408
    Nykole0408 New Member
    Hattiesburg, MS
    Just get a panel popper/trim tool. Lift the outside edge of the molding away from the car, slide the tool behind it where the clips are, and twist back and forth gently, and the clip will pop out.
  12. EF9_boy
    EF9_boy New Member
    TX
    didn't think about that.... where were you before i started attempting this lol :D
  13. Nykole0408
    Hattiesburg, MS
    :ph34r: Sorry...
    wish I would have seen this thread earlier lol. The panel popper is kinda like a hammer. It's the answer to everything lol.
  14. K2e2vin
    Raleigh, NC
    I used a trim tool and still broke mine. :/
  15. Nykole0408
    Hattiesburg, MS
    That sucks dude! :(
    I have worked in a body shop for a long long time so I guess I'm used to the limits of stuff and know just how far i can push it. Bummer.
  16. EF9_boy
    EF9_boy New Member
    TX
    can you find a pic of one somewhere?
  17. Nykole0408
    Hattiesburg, MS
