ef hatch LS swap spindles question
i have a 91 civic hatch and im doing a ls swap i read in the honda swap guide book that u should use the spindles from a civic 4 door because the spindles r bigger and the brakes are bigger but i just took spindles off a 89 civic and they look the same size is there a difference ??
the only ef you have to worry about changing the spindles on is the HF models, because the axle spindles were actually smaller on these models, if you have a dx or si don't worry about changing the knuckles or spindles
