ok here it is i have an ef that i bought as a shell and had a DA donor Car. the ef previously had a b16 turbo in it i saw it run i used same harness that he used and i couldnt get it to run had no spark no fuel. i ran dizzy straight to ecu and i also ran injectors straight to ecu and the yellow black wire straight to ecu for resistor box. map is also ran to ecu i have a videos showing you that it doesnt want to start i spray gas in IM and it fires for a few secs good i have a walboro 225 fuel pump or sso im told (came with shell) i have not yet tried to check fuel pressure i dont have a gauge. YouTube - EF LS SWAP STARTING PROBLEMS‎ PLZ HELP
Any and all help is appreciated
