Ef m.p.g?
Discussion in 'Civic and CRX - EF' started by jmende13, Nov 25, 2010.
  1. jmende13
    jmende13 New Member
    I have read threads where they talk about getting 30-36 mpg in their ef. In MY ef I am not getting near that, im getting around 22 in city. So my question is what can I do to improve my m.p.g.? I have a cold air intake and everything else is stock.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Injector flush, tune-up, spark plugs, plug wires, rotor, cap, fuel filter..... basically just maintain your car. I got 40mpg highway and 30mpg city in my 88 LX sedan.
  3. Ichigo1174
    Ichigo1174 Member
    Florence, SC
    This may sound stupid, but what is an injector flush? Just adding fuel injector cleaner/ fuel system cleaner to my gas tank and zipping along? :confused:
  4. phunky.buddha
    That's the easy way if your injectors aren't totally hosed up- give it a try first. Good garages can remove your injectors and clean them out way better than a few bottles of injector cleaner, but it costs more- not much more, but it does cost more.
  5. earlehd
    earlehd New Member
    Ga
    tune up for sure
  6. Ichigo1174
    Ichigo1174 Member
    Florence, SC
    Can't I just remove them and clean them myself? I've replace injectors on my brother's Saturn and I would think as Long as I''m careful with the o-rings I'm good as gold, right?
    What cleaners or how is the prefered methond, let them soak in a bucket of *insert cleaner here* for an hour then pop them in? (not to let the o rings soak or they will crack and become brittle.)
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Shops use special techniques/process to clean injectors; though if you want to do them yourself I've seen people rig up a unit to just spray fuel injector cleaner through them after soaking them in a cleaning solution.
    This is an example of what process shops use:
    The going rate for these types of tests are about $17-$20 per injector.
