Ef not wanting to turn on
Team OverDosed
They told me it was main fuel relay ok i unplug the relay plug back in and then it turns on but later on it will do the same thing dont know what causing it has mini me swap could it be the ecu:confused:
its v-vtec not v-tech... anyways... not having the v-tec hooked up wont cause that... check ur grounds stuff like that.. try getting a new relay or something.... nothing comes on?? at all
my lights and stuff turn on car turns over but does not start sometimes it turn on then it dies right away tried a friends main relay turn on for a little while but contuinued to die:confused:
its definitely not v-vtec either
is the ecu throwing any codes?
