ef rear brakes
sinezter
ok i have a 89 crx with rear disk brakes and i have a 89 ef hatch and i wanted to know if the crx rear brakes will fit on my ef hatch? if they do then what parts am i gana need? i know this topic has been covered 1000 times with the rear DA brakes, but what about these crx brakes?
thanks for the info
I did the swap with DA brakes, so I may not be correct on everything but I can give you a general idea.
You'll want to use the civic compensator arm that controls toe, the civic and crx ones might be the same length, but I don't know. You'll also need to use your civic's e-brake cables....crx ones would be too short. I don't know if a crx master cyl. will work or not, but if it will, i'd use the Si one, or one from a DA integra...there are better ones to use, but these will work good enough..
I may have missed something, but thats what I can think of...
