hi im new here searched a little bit but im wondering if somone could tellme straight up since theres not alot of threads covering ef sedan swaps.only crxs basicly....
if i had 1991 civic sedan and wanted to put
b16a obd0 swap into it what would i need to do
what mounts/brackets do i need to get
how hard would it be to wire ( ive wired a obd2a civic dx harness to run a obd2a b18b before..)
what would i need to do about the tranny / shift linkage ( iunderstand id need to trim the linkage by 3 inches to get it to fit??)
im also comptemplating
putting in a b18a becuase itd have a higher chance to smog and def. cheaper.
so could i run a 1991 integra ls ecu with a stock ef harness ?
