wat harness do i use if im swappin a b16 into a 90 ef and since i did the dpfi to mpfi already will i have to pin swap agen for the b16 i have an LS now i cant jus drop the b16 in wit out doin any wiring?
Terrible info. It should be exactly the same as your LS except you will need to add the wires for Vtec. Assuming you are using an OBD0 ECU, like would be in a 2nd gen CRX SiR (PW0/PR3). None of the B16a that came out of the 88-91, 92-95 Civic SiR/SiRII had a number after the "a".
