Ef with gsr speedo electric or cable?
Discussion in 'HYBRID -> ED-EF / DA' started by 1991gsrhatch, Nov 11, 2015.
  1. 1991gsrhatch
    1991gsrhatch New Member
    im swapping a gsr into my Ef hatch. Going to be using the p72 Ecu. Also using a hydro b16 trans. Will I need to use the electronic speedo vss for vtec to work properly? Also will I have to wire it into my harness? I heard that the Ef had a wire from the factory speedo to the Ecu. Not quite sure. Thanks for the input.
