ef wont start!?!?!?!?! HONDA NEWBY
Discussion in 'Civic and CRX - EF' started by ef90swap2ek, Mar 20, 2010.
  1. ef90swap2ek
    ef90swap2ek New Member
    i jus bout a ef hb with a ek sohc 1.6 non-vtech swap.
    i changed the main relay and powerd up then,
    found out that the radiator was cracked changed that out n now wont start.
    ok but heres the thing it was never started suposably after it was swaped so wen i put the relay in it boged real bad i dont know if it was cuz no radi. fluid or wat but after i put the new radiator in n the fluid it dont start.
    i unplug alot of shyt so it cant start at night so it wont get cuffed n i plugged every thing up put new battery an still wont but it wants to so bad ....... im pissed
    CAN YALL HELP
  2. Mike Diaz
    Mike Diaz Junior Member
    download bonsai buddy and install it to your ECU's rom. It's located in the passenger kick panel.
  3. ef90swap2ek
    now how do i do all that i know were my ecu is but i dont know how to fuck wit it can u explain by any chance?
  4. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    Post in the proper forum section. Unless you're selling or buying parts this is not the place for tech.
  5. ef90swap2ek
    idk how to use this thing yet i dont know were to go
  6. Matts96HB
    Matts96HB . Moderator VIP
    ok, so the car will crank over but will not start.
    you need three things to start a vehicle.
    1) correct timing
    2) fuel
    3) spark
    if you have these three things, your car will start.
    the best way to go about it is this:
    1) check to see if you are getting spark. get a long screwdriver or a piece of metal, and shove one end inside a spark plug wire. touch the other end to the ground on your valve cover. try to start the car. if theres a spark, youre good. if not, then you have a spark issue.
    2) check for fuel. easiest way to do this is to just pull the line from the fuel filter to fuel rail off and stick the end of it in a water bottle/bucket. try starting the car. if fuel comes out, then youre good. if not, then youve got an issue with fuel.
    3) check for fuel at the injector. pull one injector out (but keep the end of it in the fuel rail) and crank it over. if you don't have fuel there then you know that the problem is most likely electrical because the injectors aren't functioning.
    4) after youve done all that, you can check to be sure the timing is on. pull the timing belt cover and turn the engine over to TDC on cyl #1. the hash mark on your crank pulley should be lined up with the arrow on the oil pump/lower timing cover. the cam gear should be pointed almost straight up where it is marked "up" (maybe slightly forward due to how the engine sits in the bay).
    if you do all this correctly, you should be able to isolate your problem.
    ??? dont be a dick. hes asking a legitimate question here.
    disregard the above post, hes messing with you.
