ef8 sir idles but doesn't rev
Discussion in 'Civic and CRX - EF' started by joncivic1, Jan 31, 2009.
  1. joncivic1
    joncivic1 New Member
    n wales
    i have converted my ef8 to obd1 it idles lumpy and cuts out under any amount of throtle any1 experianced this:(
  2. efhondakid
    Akron-Canton, Ohio
    The CEL on?
  3. MthaFuknGreen
    Lodi, CA
    are you out of gas or close to it?
  4. joncivic1
    n wales
    CEL? I am a biginner in this department
  5. joncivic1
    n wales
    gas is good me mate prooved that when testing injectors got me in the eye quater tank reading anyway everything seems fine (a litle slow and lumpy but ive seen worse run, into vtec aswell )until throtle is opened
  6. MthaFuknGreen
    Lodi, CA
  7. joncivic1
    n wales
    engine light comes on aftee 30 secons of idle
  8. MthaFuknGreen
    Lodi, CA
  9. joncivic1
    n wales
    would lamba sensor wired wrong cause sutch problems
  10. MthaFuknGreen
    Lodi, CA
    lamba sensor?
    are you just making shit up now?
  11. joncivic1
    n wales
    as my distributor and laba sensor are from obd2 cars and ecu obd1 i got a leaflet of info with conversion harness followed it to the t only to get the results i am reporting could this be becausemost conversions are based on obd1 and i might have got a wire wrong
  12. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    what is a laba sensor?
  13. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    haha i too saw this and let out a loud wtf? obama sensor?
  14. OGMatt
    vic B.C. Japanada
  15. HATCHET_HONDA
    hobart, indiana
    sooo is this motor obd1 or 2? if your dizzy is obd 2 and ur ecu is obd1 w/o conversion bein right its gonna run all whacko if at all
  16. joncivic1
    n wales
    right sit back relax and read on
    b18c4 block and distributor, lamba (O2) sensor (european gsr i believe) obd2 from 1999 civic vti aero
    b16a head 1990 crx sir used due to diferent obd0
    ecu p30 from crx vti 1994 obd1 with harness addapter from HOND-R.CO.UK
    all above worked fine in my eg3 civic
    so as 4 run well kept me on the road for 4 years like that until the suspension colapsed going round corner so as for whacko you wouldnt belive the frustration it caused others.
    NOW progress if you wish to help and stop taking p*ss
    firing order is right
    good spark fueling well ecu light comes on 30 seconds in. It is only firing 1 and 3 even though good spark to 2 and 4 am going to get compression tester as the twat that changed the head origionally put gasket back to front so have suspision of bent valves. (head mechanic) was done in a garage
    So if any of you can point me further in the right direction without taking the p*ss i would be verry gratefull as my day job is a chef not a greese monkey and i have got this far working around my job without the help of so called mechanics that have let me down several times with this car because they cant seem to work it out because they are all vw or opel fans this is a bit beond them just the thought japanese makes them sweat
  17. prpprimo
    prpprimo Hondaholic
    ABQ
    Been there done that, it drove me civix!
    after days of research, on another site.
    I read one sentence that made all the difference in the world.
    Here it is.
    " Be sure to shield your distributor wires";)
  18. tabKola
    tabKola New Member
    Tewksbury MA
    I think by Lamba sensor he means Oxygen sensor and yes if it is wired wrong it could cause this because your A/F ratio will be off.
  19. HATCHET_HONDA
    hobart, indiana
    is that a european thing? callin an o2 a lamba sensor?
  20. joncivic1
    n wales
    yep dno why.
    cool will have to double check with suplier of harness then becaus they suplied me with info to re wire it
