Lots of ignorance on here.
Lambda is a common unit of measure in tuning and common in chemistry. ie. 1 lambda=stoich, or for gasoline engines, 14.7:1 air/fuel ratio.
"American English" is not always the same as the world/other English. A car hood=bonnet, a windshield=windscreen, driveshaft=propeller shaft, fender=wing, etc.
Anyways, try what PRPrimo suggested, and also check your wiring(make sure the TPS isn't wired backwards).
lots of ignorance on here.
Lambda is a common unit of measure in tuning and common in chemistry. Ie. 1 lambda=stoich, or for gasoline engines, 14.7:1 air/fuel ratio.
"american english" is not always the same as the world/other english. A car hood=bonnet, a windshield=windscreen, driveshaft=propeller shaft, fender=wing, etc.
Anyways, try what prprimo suggested, and also check your wiring(make sure the tps isn't wired backwards).
welsh you yanky twat thought you gays new all the shit so os ryduch chi ddim yn deallt be da chi yn ei shiarad amddam cau yr twll mawr na a paid a malu cachu cont
