ef8 to b16 change axel hubs?
aos
bought crashrd crxb16 but has damaged frount axel/hub i want to put b16 into my crxef6 both 91 will i need new axel or will crxef6 axel do ?
[post=488410]Quoted post[/post]​
your stock axle will not work - you need 90-93 Integra axles - is your car DX/Si or HF? if HF you will need to swap knuckles/hubs for ones from DX or Si in order to use the larger axles
I dont think he's from around here... hints the ef6... our chassis were ED's...
Brian
think its a dx but not sure its the 1.5 dual carb sohc 16 valve year 91.by the way Brian im from cork you langer
cork is in the south of ireland and a langer is a dickhead (cork slang)
