Effects Of Running Turbo W/out Charge Pipes
Discussion in 'Forced Induction' started by pub, Mar 27, 2003.
  1. pub
    pub Junior Member
    Plan on driving my turbo without being hooked up to the throttle body 5 miles home. Not planning on actually getting the RPM's high enough for me to actually create boost in the compressor outlet. (So under 3000 the whole trip home)
    I was wondering if the turbo would 'overspin' without having the charge pipes connected and if this would cause any long term damage to the turbo itself?
  2. civicb18
    civicb18 Member
    IOWA
    well i personally would not cuz there is always that chance, why dont u just take it off and drive home open manifold
  3. pub
    pub Junior Member
    for one.. noise.
    plus theres quite a bit of meltable objects in my engine bay.
  4. poid
    poid Member
    I need to know how to do this as well, seeing as there is a good chance i will have to drive 300km to get to a decent tuner after my piping is done. I was thinking disconnect the piping to the TB, and basically cover that end with a cap of some sort with a small hole in it. Would that at least prevent the turbo overspinning?
  5. redtao
    redtao Member
    I won't recommend driving without the turbo on or open manifold, the distance is too short to the head and cold air could flow back into the engine cooling it to fast and warp your valves.not to mention fire would be blowing out meltings things. if you drive slow withouth the charge pipe to the tb it should be ok. better if you put some sort of filter to the tb.
  6. pub
    pub Junior Member
    what the hell? haha
  7. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    "the noise" ? What a pussy. If the wastegate is set properly your fine, it will still regulate the turbo properly charge pipes or not. It's probably still not the sweetest idea man.
  8. Bri94lst
    Bri94lst Senior Member
    riiiight...try telling that to everyone who has a short ram or CAI
  9. boostdGS
    boostdGS Member
    and you think open compressor is gunna be any quieter?
    put some charge pipes on your car, and drive home
  10. SolReaver
    SolReaver Senior Member
    wtf are you talking about? have you ever driven a car with no charge pipes and the turbo installed? all there is to worry about is a little bit of whistling....i drove 3 hours straight with no charge pipes and everything was all good
  11. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    DUDE. Do you realize that the wastegate references the boost level before opening the wastegate at all? No charge Piping = NO BOOST = NO WASTEGATE CONTROL.
    Jeez.
    I've seen cars driving around without charge pipes hooked up without worries. DO NOT get on it, DO NOT make it a habit, and you'll be fine. Take it easy, keep the RPM under 3000, less than 1/4 throttle, and take it SLOW. Pretend you're pulling another car behind you with a 15 foot rope if that idea helps you at all.
  12. liquid00meth
    Laconia, NH
    Set the wastegate at 0 psi nutballs
  13. heterosapian
    heterosapian Senior Member
    exit 152, I-95
    Sounds good. But nutballs? Isnt that a bit redundant?
  14. redtao
    redtao Member
    yo! man can i get slapped, forgive me on my post earlier, i don't know what the hell i was talking about. I work at night and when i posted that crap i was up over 24hrs and i thought he was talking about the exhuast manifold. I don't know why i thought that. that goes to show you what sleep deprivation can to you. get your sleep!!!
  15. pissedoffsol
    i've never seen a wastegate spring that is 0 psi :bash:
  16. boostdGS
    boostdGS Member
    yea, actually i have driven a car with no charge pipes. MINE.
    It's not safe, and what i meant was open out-let compressor, not the inlet, dumbass.
    It would be ouder than an open downpipe, and don't even tell me that's quiet. So I suggested to NOT drive his car around, and stop being lazy and go out and find some charge pipes. I think he'd rather take the time to do things right, than risk blowing his turbo. I mean, how much could some charge pipes cost from home depot, 20 bucks with silicon connectors?
  17. SolReaver
    ur dumb :thumbsup:
    you recommend not taking the lazy route, yet say to go get some charge piping at home depot, with non- existant silicon couplings? silicone couplings are 4 bucks each and the are NOT available at home depot, trust me i spent 6 hours driving around trying to find some 2 weeks ago
    and you wont "blow your turbo" as long as you keep it under 3k rpm and light throttle! damn read sir kid's posts ^^^!
  18. liquid00meth
    Laconia, NH
    yes, I was just retorting to his comment. I don't really dislike or discredit him - just poking fun.
  19. boostdGS
    boostdGS Member
    whatever you say chump, go ahead kid, drive around all day with no charge pipes, and have a good day.
    and if you can't find silicon connectors anywhere, then you're retarted. Go to any decent hardware store. I got my friend some from a local hardware shop, and If home depot somehow doesn't have them, then go to a different store.
  20. liquid00meth
    Laconia, NH
    Ever heard of an adjustable internal wastegate actuator? Manual adjustment? rig something up? Don't be bashing me. I was just defending my earlier comment, it was not wrong - Sir deemed it necessary to insinuate that I had just suggested something that was an unimaginable atrocity - when in fact it was quite simple. Bottom line is, the kid should should learn from the suggestions. If you understand how the turbo system works, you can easily see in what and what not situations you could run without charge pipes.
