Eg conversion help from ek
Discussion in 'Civic and del Sol - EG and EK' started by Deanireland, Jul 26, 2016.
eg3 conversion with ek parts
  1. Read treat tread look down
    0 vote(s)
    0.0%
  2. Tread the tread look down
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Deanireland
    Deanireland New Member
    I have done ek conversion loads of times easy job
    Now I'm going to do the eg3 conversion I need help I have a ek coupe that has a b16 vti in it...
    All I know is il have to change the engine loom and dash from eg6 9 or dc2 and Ecu..
    I want to know if the side engine mounts are the same and just put b back mount in like the ek..
    And can I use the tank from the ek and fuel lines I can't see why I can't i was told I can't...and the eg3 hubs will the 97 ek b shafts fit in or Wil I have to use the ek shafts
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    ... .... how about compare some parts and realise theres lots of variables here, also dont post multiple threads for the same issue, welcome to hondaswap
