Quoted post[/post]]
done it! it will fit on all bolt are the same and it all the same size and shit!!! the only difference is a lil one after you put the bumper on stand back and look at the front!! it have one long vent as the hatchy and coupe have a big on int the middle and 2 lil ones on the side!!!
and if you look at the headlight and thre bumper under it the body line is about 1/2 to a 1/4 inch off but nothing you can sopt just by lookin at it!!!!
and most 4 dorrs dont have the lil bolt on lip idk what they call it i guess si lip?
Quoted post[/post]]
as i put up there they will bold right on wit no fabing!!!! and those are the lil differences you will see on the car i have dont it wit no fabbing many times
Quoted post[/post]]
here is a easy sloution get then bumper and try to put it on w/e you tryin to put itn on and you will see for you self !!! and you will see that it is no modds needed to use it!!!
Quoted post[/post]]
Hey guys! I'm wondering if the hatch or coupe front bumper off of the EGs fit the 4dr EG?? I've seen people do it but is there any fabrication (cutting/drilling) in order to make it fit? Thanks!
Quoted post[/post]]
Quoted post[/post]]
When we purchased our project car I was told the hood was from a coupe, front bumper from a hatch and cannot recall where the fenders are from. We have an alignment issue with the drivers side fender which I'll try to fix down the road. There is also a larger gap between the bumper and hood.
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
who are you and what
Quoted post[/post]]
Thanks GUYS!
