Eg crisis!!
egeezy
i got a canadian eg, i just dropped a b16a2 into it. b16A2, Built Gsr Head, ITR cams, b16 trans. i had this swap in a us eg ran perfect. now whith this car it idles up and down and when i unplug the tps sensor it runs fine for about 5 miles then goes into limp mode. i fried my chipped p30 last night. how do you install the ELD elctrical load detector onto the canadian model car? if that is even my problem as i have heard
a buddy had the same issue with his gsr. his specific issue was a clogged iacv. same temp fix too, remove the tps plug and it was good for a while, just had 0 power (to be expected) after about 5-10 minutes.
us and canadian are NOT the same the us Engine wire harness has a map sensor in it. the Canadian engine harness does not have a map sendor plug it is in the CAR harness. i also did a direct drop no wiring and it has vtec
Also, it cant be a clogged iac becasue i had this head and manifold on another b16 and it was running fine until someone mis shifted it
sounds like you should check your iacv screen and possibly your iat, that was my problem when my car surged up and down
3 wire iacv, i cleaned it traced for leaks sprayed brake clean all around the manifold no rpm raise or drop. i bought a ostrich emulator and chips and the base map for a edm b16a2 disables knock sensor, ELD, atmospheric pressure sensor. so im gonna mess with my chip and c what i can come up with
