Eg - ed b18 manual swap.
Discussion in 'HYBRID -> ED-EF / DA' started by Deancivic, Jan 3, 2014.
  1. Deancivic
    Deancivic New Member
    Okay guys. At the moment my ed is auto, carby.
    I bought a smashed eg with a manual b18c2 in it.
    Looking into swapping the b18 into my ed.
    What troubles will I go through? I assume people have done this?
    Thanks in advance guys :p
  2. Fernpatch
    Fernpatch Member
    Bellingham,WA
    this is not a complete list but off the top off my head you will need:
    a set of swap mounts and axles. you may also need to install different wheel hubs for the new axles
    a major re wire for efi
    a complete new fuel system from the tank forward for efi
    you will need to purchase clutch pedal hardware, shift linkage etc. or try to modify the eg parts to work.
    you will most likely need more but i am too tired at the moment to keep thinking about it.
