capone9399
would coilovers from a 92-95 work with a 88-91?
I know the shocks are different from 88 to 89, the 89 has the U bracket thing at the bottom, whereas the 88 just has a hole for a bolt to go through.Quoted post[/post]]
I believe spring-wise (which includes coilovers) everything is interchangeable from 88-00
Quoted post[/post]]
yeah, shocks are different in '88, '89-'91, '92-'95, '96-'00.
Springs are all the same though IIRC.
that's only partly true because I know for a fact that the rear shocks from 89-95 are the same, the fronts might be different but i'm not positive.Quoted post[/post]]
Quoted post[/post]]
