eg gsr not starting
Discussion in 'Civic and del Sol - EG and EK' started by 91efkilla, Feb 5, 2011.
  1. 91efkilla
    91efkilla New Member
    Ok. SO here's my problem. Broke the gear selector in the tranny. Car was able to start with no problems. Took the tranny apart replaced the gear selector. After we put everything back we tried to start the car but the battery was dead. So we pushed it and popped the clutch. Wala....it started no problem. We let it sit and run for about a half an hour and then we drove away. 2 mins into driving the car bogged down and died. Come to find out the tranny ground wasn't holding good. We snugged it down and tried to start the car again. Nothing. We pushed the car again and popped the clutch. Nothing. Check all fuses and they were good. Tried to jump start the car cause battery was dead and still nothing. I replaced the tranny ground but still nothing. I checked the ecu and I found pin number 25 to be burnt to crisp. So I check the ecu. It's bad as well. So I cut the bad part of the wire and replace the ecu and still car won't start. We didn't replace nothing besides taking the tranny off and then back on. The starter I took to autozone and it tested to be good. When you crank the motor you can see the starter turning the flywheel. but it won start. I don't know what else to look for here......can anyone help??????? text me at 646-537-5668 if you have an idea...
  2. 91efkilla
    bump.....any idea will help me right now
  3. E_SolSi
    you do not need to bump this after 10 minutes
  4. 91efkilla
    Any Ideas can help guys
