torturedsol
Sup ladies and gents:
I usualy lurk around at the abundence of info on the site. Ran into an issue with my h22 swap in my 92 Civic.
I bought a JDM H22A swap from a local guy. Motor is minty, trans is pissing me off. I'm running a 93 Accord intermeadite shaft w/ 93 GSR Axles(So I've been told) and I can't seem to get them to seal. I've got at leaste 10 axle seals that fit the trans housing and axles but still pouring gear oil out between the axle shaft and the seal. They arn't tearing when I put them in with my seal driver and I lube the inside of the seal before I slide the axle in.
You guys have any ideas as to why this is happening? Or, am I better off going back to the parts store and getting, yet another, pair of axle seals and set of axles I know are for a 90-93 Integra? Side note to that: Should I order Prelude axle seals or Integra? The OD of the seals are realitivly the same according to NAPA and Advance spec sheets. I'd get some from the stealership but I don't have one within a reasonable distance.
The setup is again:
92 Civic Hatch
JDM H22A/Trans
Accord intermeadiate shaft
Claimed Integra Axles
Thanks in Advance.
The setup is again:
92 Civic Hatch
JDM H22A/Trans
Thanks in Advance.
