EG H22 Swap, Drive shaft question.
Discussion in 'HYBRID -> EG-EK / DC' started by Cablerat, Feb 22, 2005.
  1. Cablerat
    Cablerat Junior Member
    I have a 93 SI Hatch with an H22 using HCP mounts.
    I'm looking to put in some performance driveshafts as opposed to stock Integra shafts. I can't for the life of me find any shafts that would fit properly with the HCP mount positions.
    I've tried to email HCP directly, but their email is DEAD.
    I know ENJO for example makes performance shafts for the EG / H22 swap using their mounts, but I wanna know what performance shafts I can use with the HCP mount setup.
    Any help is appreciated.
    Thanks,
    Cablerat
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    HCP recommends the following
    Axles 90-93 Integra Axles w/90-93 Accord 5-spd Mid-Shaft
    90-93 Integra Passenger Side Axle w/86-89 Integra Drive Side Axle (Use Inner Prelude Joint) w/92-96 Prelude 5-spd Mid-Shaft
    another note: HCP is rumored to be a duplicate of hasport mounts, so i would think hasport AXLES are what you are looking for...
    driveshafts are for RWD
  3. Cablerat
    I'm running that recommended combination for almost 2 years now.
    I'm going to be increasing the power output significantly soon and stock shafts will not suffice.
  4. reckedracing
    NY
  5. reckedracing
    NY
