eg hatch with b18a1
Discussion in 'HYBRID -> EG-EK / DC' started by 93EGBubble, Aug 22, 2009.
  1. 93EGBubble
    93EGBubble New Member
    i just bought a 93 hatch with a ls motor with a gsr head. car runs but idles between 1000-1500rpm idle fluctuates the car doesnt have an intake on it and the vacuum line coming of the head isnt hooked up, and there is 3 or 4 connectors not plugged in and i cant seem to find where they go or where they would go but for starters any idea why the idle fluctuates. the cel is on by the way.
  2. nicefighter80
    nicefighter80 New Member
    first check the code that will help alot, check your map sensor and vacuum cause mine does that and i got the map unplugged
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    You need to get a Helm manual for the motor/head and look into parts that aren't hooked up
  4. 93EGBubble
    well the rod came through the block at 3k rpms in my driveway on sunday ill have a new b18a1 block on saturday. im going to start fresh with forged rods and pistons. then after my motors done im going to buy a megasquirt ecu and then buy my turbo parts. ill get the manual and look at everything once i drop the new motor in. thanks. but just curious whats an estimate on hp the stock ls sleeves can handle?
