What would be the easiest way to wire in the IAB valve. I was thinking about using the plug for the egr lift solenoid valve that isn't being used. Then replace the plug so it connects to the IAB solenoid valve. Then on the ecu taking pin A11 for egr lift solenoid and install it pin A17 IAB soleniod spot. If someone knows an easier way please let me know. Thanks
