eg mount help
JDMwannab2
lets see here...im getting a B18 motor outta a eg for my ek. were tradeing my D16 engine thats in my ek for the B18 plus cash bla bla bla...the thing is that the guy wants to put the D16 in the eg so he can trade/sell it off. my question is wut motor mounts do i need to put the d16 into the eg??..will the stock ek mounts work? the year on the eg i think is a 95 an the ek is a 96 year model
Probably won't work. I'm pretty sure you will need the drivers side mount. The others should be fine.
you can use the ls mounts IF your putting the LS into an EG. as far as putting the sohc into the ek chassis, you need the factory mounts for the ek chassis with sohc.
