eg rear arch repair
tat
hi guys ive got a 95 civic and i need to get repair panel for the rear arches for both sides where can i get some cheap
Hit your junk yard and pick up some front fenders and use the opposite side for the side you need to repair. Example: If you need to repair rear driver, take your fresh from the junk yard front passanger fender and flip it. Cut your rust part out. Cut same size piece from JYS fender and weld patch piece in and wala you got yourself a repaired rear wheel arch.
