trust me.. you just want to get it fixed. or else it will keep coming back and back and back..lol. And to answer your questions GSRCRX. There are a few ways to achieve the flat black look. I chose the Krylon way. And i didnt say i only used one can of paint. I said only one got empty. The rest are still atleast 1/4 full. What would happen with the cans, was when i was painting the nozzle would clog up and i would just swap cans, then i started swapping nozzles. But i used 4 cans. Now im still not done, but i think i have enough.
Now as far as what i did.
I'm not a painter, i dont consider myself a pro, and i dont make my living off painting cars..but what I've heard is that spray paint isnt a paint that seals... which makes sense IMO. So if you were to sand your car down to bare metal and paint it with spray paint, it would rust because the paint wouldnt seal like a normal paint job you would get at colorpros shop. So for this reason i didnt sand down to bare metal, nor did i even get to the primer in the majority of the places. I just scuffed up the paint enough so that the spray paint would have something to grip and the regular paint under it would protect the metal under it. So sand your whole car down just scuff your paint up. I used a 220 grit paper w/ a sander, it gets real dusty so do it in a open area, drive way or something like that. This would be a good time to tape off your rubber seals and shit. you dont want the sander catching them. Then wipe down the area and look for the shiny spots where you skipped or missed or whatever, then sand those spots.
Now that the car is sanded, i used a automotive laqour thinner from a car paint shop (that a friend had) and rubbed the whole car down. This cleans the body up, again.. do this in a VENTILATED AREA.. the shit is strong and will fuck you up. If you see shiney spots after cleaning the surface, sand it again, then clean it again, repeat till your car is dull. After the area is all cleaned up i took parts off and taped stuff off and started painting. i put several coats on it.
wait till dry.. a day, more, whatever. This is where I am right now, and im going to be doing this weekend. This weekend im going back over my car and wetsanding it with 800 grit. This will help get some of the painters and spray cans errors in the paint job and give it that smooth flat look. And then after im done with this im probably gonna go over it again, then wetsand it again and see how it looks.
CLIFF STEPS:
1. Sand car down, just scuff up paint, dont sand to bare metal
2. Clean sanded areas down, then wipe with a good quality automotive laqour thinner
3. Tape off, remove parts, and paint.
4. Let dry.
5. Wetsand painted area.
6. Repeat 3,4, and 5 till happy with car.
Materials: (that i used)
220 grit sandpaper (to sand the car)
laquor thinner (clean the car)
4 cans of Krylon Ultra-Flat Black Camo Paint (The camo isnt necessary, just use what you want, flat black , black, ultra flat, whatever)
800 grit sandpaper (to wetsand the car)
masking tape and newspapers (self-explanitory)
And to answer the last few questions.. i didnt use and i dont plan on using any sealer. And my door handles are fine. They arent rubbing off, why would they?? And if they even did, who cares.. shake the can up and apply then your done
Hope this answers all your questions.. if not, just ask away.
