eg vs. ef springs
Yes; although advertised drop heights may be different(IIRC, the EF will sit higher than compared to EG's with the same spring).
ok if thats true what would you think the ride quality of tein luxury master springs and tokico gas struts as a combo will it be a nice ride
I have no clue since I don't know the spring rates; but I'm willing to bet it is.
the eg struts are longer, you can use them but you need the strut fork from an ef, and it will still sit higher than it should, project car magazine just put eg shocks/springs on a crx they built..
kinda neat info... i know the front of my car sits about half inch lower than back this could be a way to level it out and get it up some.
not likely ill do it but for others it could be good.
