EG wire tuck...
Discussion in 'Civic and del Sol - EG and EK' started by EP3Hatch1987, Nov 18, 2009.
  1. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    my new build.. im getting new turbo manifold.. bisi spec (hurricane hedi turbo.. lol) and doing a full wire tuck.. also might be getting harness from rywire.
    tucked injector harness.. easiet 1..
    pictureof before with battery and fuse box removed already..
    body harness removed waiting 4 new 1..
    waiting for turbo 2 come in from bisimoto..
    car tookin apart and fresh paint by ME.. was red sprayed black
    juss waiting 4 parts now...
    FInished running the head light harness on driverside got everything where i want it...
    also removed the dash 4 a lil easies access and 2 do the full tuck 4 everything 2 meet in the middle of the dash 2 be hidden..
    pulled the engine harness out had 2 do some mods..
    took off all the heat resistant stuff..
    the partical finished product.. need some heat resistant nylon.. un tangled them and wrapped individually..
    pulled the heater core out.. so i can stick the wire threw the hole..
    didnt get into much detail after this juss wanted 2 finish my project so heres the final result hope you guys like it....
    AND USED ALL THE STOCK HARNESSES.... also a thanx 2 my boy phil 4 helping me with the tuck...
  2. EP3Hatch1987
    Guessing nobody liked it....
  3. sufikation
    sufikation Active Member
    Fruitland, ID
    Thats a clean job man, good luck with the rest of the build.
  4. jaxdime
    jaxdime New Member
    how do u like that dampener of the dr side of the motor thats the first one of those ive seen and my 89 hatch could really use something like that
  5. EP3Hatch1987
    It works well.. But if I had solid motor mounts that would help a lot more.. But overall it works good..
  6. ZCpowerdSI
    ZCpowerdSI New Member
    ON, Canada
    Awesome, looks really clean.. Good Job man :thumbsup:
  7. EP3Hatch1987
  8. efhondakid
    efhondakid My name is Byron.
    Akron-Canton, Ohio
    I dig it, keep up the good work. :thumbsup: 3M WindoWeld, fill the gaps in the OE mounts with it.
  9. EP3Hatch1987
    Does it really work? Have you done it?
  10. efhondakid
    Akron-Canton, Ohio
    Not personally, but Ive heard it works very well.
  11. WR grim
    WR grim New Member
    ny
    The 3m stuff works great if the mount is not already broken. If it is broken then it dose not hold up in my experience.
  12. EP3Hatch1987
    Juss wanted 2 bring it back 2 life....
