eg with b18b1 harness question
Discussion in 'HYBRID -> EG-EK / DC' started by Wokam, Aug 24, 2007.
  1. Wokam
    Wokam Junior Member
    Midwest
    Will an engine harness from a 95 AUTOMATIC Integra LS work in my eg with obd1 LS and a MANUAL tranny?
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    Use the harness you have now that came with the car. You dont need to change the harness to run the new engine. If the engine is obd1 your harness will be plug and play. Make sure you have the obd1 ecu that goes with it as well. If your new engine is obd2 you can get obd1 dizzy, injectors, and alternator to make it plug and play if you dont want to change plugs.
  3. Wokam
    Wokam Junior Member
    Midwest
    The harness that came with the car has all of the connectors cut off.
  4. boostin4fun
    Omaha
    The harness is in two pieces, there are the 3 plugs on each side of the car that come from inside of the car to the engine bay. Then the engine harness plugs into that. If the plugs that come from inside the car are still intact, just get another eg harness that hasnt been all hacked up. That would be your easiest and really only option.
  5. Wokam
    Wokam Junior Member
    Midwest
    The engine is a 1994 LS with a GSR manual tranny. I swapped the engine and tranny into my 92 civic VX. Currently, the engine and tranny are both bolted into the engine bay. The wiring in the dash is intact all the way to the shock-tower connections. All i need is an engine harness because the one i got with the engine is all cut up. Everything im working with is OBD1 and non-VTEC. Im just wondering if a harness from a 1994 LS engine with an Auto tranny will work? It should, right? With the exception of a few extra connectors that would go into the automatic transmission, since mine is a manual.
  6. boostin4fun
    Omaha
    I cant say for sure I have never run into that problem before. If the integra harness plugs into the strut tower connections fine you should be alright I would think.
  7. boostin4fun
    Omaha
    If the connections are not the same just get a harness for the eg and it should be plug and play.
