eibach prokit springs w/ kyb agx -or- koni yellows?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by bxstylez, Aug 3, 2008.
  1. bxstylez
    bxstylez New Member
    i've been running the kyb gr-2 shocks/struts for about 2 weeks and gone through several springs
    with the stock springs... it wasnt that bouncy
    then as i changed to skunk2 adj. coilovers from ebay (probably about 2.5" drop).... the ride was too low and unbearable in NYC.... keep in mind that i'm running 195/60/14 tires
    i felt every bump/pothole, and bouncy as hell
    had these on for 1 day
    then i got the h&r springs (rated 1.8" drop front& rear) .... still kind of low for me and less bouncier than the skunk2
    had these on for 1 week
    now i've got the eibach prokit springs (1.2" - 1.4" drop)
    ride height is semi-perfect.... yet still bouncy (less bouncier than the h&r's)
    i'm definitely keeping the eibach springs that i currently have on right now
    my question is..... should i get koni yellows all around for about 550 from ebay?
    or just change the front 2 struts to kyb agx's?
  2. TurboMirage
    get yellows all the way around if you can afford it. if not, the AGX will be great.
