ej2 b20b4 swap
crxpower24
Sorry for the question so I found a b20b4 for cheap its out of a 98 crv but I can't find any info on this swap what I'm asking is what obd is the b20 or what all do I have to do to make this engine run in my ej2 any info on this swap would be highly appreciated.
Well your OBD1 and if im not mistaken its an OBD2 motor... You would need a B18 or B20 Auto or Hydro Trany.... The ecu, need the axles, maybe the wiring harness and OBD1- OBD2 connector ect
Convert the engine electronics (dist, alt, possibly a few more (I'm not too familiar with this swap) to obd1 is the easiest thing to do. then run an LS ecu, p75. Ideally, get it chipped/dyno tuned to run the b20 but the p75 is prob close enough to get around.
